抗震 通信 -----生命電波 轉貼-----
 樓主| 發表於 15-5-2008 10:59:55 | 顯示全部樓層
 樓主| 發表於 15-5-2008 11:00:35 | 顯示全部樓層
 樓主| 發表於 15-5-2008 11:06:06 | 顯示全部樓層
 樓主| 發表於 15-5-2008 15:23:12 | 顯示全部樓層
<pre><tt>From: WRRL [mailto:<a href="http://hk.f366.mail.yahoo.com/ym/Compose?To=wrrl@cot.net&amp;YY=52991&amp;y5beta=yes&amp;y5beta=yes&amp;order=down&amp;sort=date&amp;pos=0&amp;view=a&amp;head=b">wrrl@cot.net</a>]<br> Sent: May-14-08 9:07 AM<br> To: Undisclosed-Recipient:;@priv-edmwaa15.telusplanet.net<br> Subject: SPECIAL BULLETIN - <font size="6"><span style="color: Red;">ALL RADIO AMATEURS</span><br style="color: Red;"></font><br><br><br><br> THIS BULLETIN IS BEING SENT TO MULTIPLE EMAIL GROUP FILES.<br> IF YOU RECEIVE MORE THAN ONE COPY IT IS NOT A MISTAKE.<br><br> DISSEMINATE AT WILL<br><br> TO: ALL RADIO AMATEURS<br> FROM: W7RRL - WORLD RADIO RELAY LEAGUE HQ<br> DATE/TIME: MAY 14 2008 1600 UTC<br> SUBJECT: CHINA DISASTER<br> REFERENCE: MESSAGES BELOW<br><br> PLEASE PASS THIS BULLETIN TO ALL RADIO AMATEURS ASAP:<br><br> Please do not use <font size="6"><span style="color: Red;">14.270 MHz</span></font> for the time being. It is being used for<br>relief efforts in China.<br><br> ---------  Forwarded Message ----------<br><br> A Magnitude 7.8 earthquake hit Sichuan, China on Monday, May 12,<br> 2008 at 06:28:04 UTC.  Casualties and loss unknown up to now.<br>  According<br> to Chinese Radio Sports Association, <font size="6"><span style="color: Red;">14.270, 7.050 and 7.060 MHz</span></font><br> are reserved for amateur radio emergency service in the rescue.<br><br> A group of radio amateurs is now transmitting from Wenchuan, the<br> center of quake.  Their signal is reported to be very weak. They tried<br> to<br> keep communication with BY8AA in Chengdu, seeking for all resources<br> needed.  During a contact finished a few minutes ago, they were asking<br> for raincoats, water, tents, and outdoor living facilities.<br><br> Please spread this message as far as you can and keep the frequencies<br> clear for emergency use. Thank you.<br><br> Michael Chen, BD5RV/4<br></tt></pre>
                  <!-- toctype = X-unknown --><!-- toctype = text --><!-- text --><script>
var callCount = 0;
function rmvScroll( msg )
        if ( ++callCount > 10 ) { msg.style.visibility = "visible"; }
        if ( callCount < 50 && ! imgsDone( msg ) ) {
                setTimeout( function() { rmvScroll( msg ); }, 200 );
                return;
        var delta = msg.offsetHeight - msg.clientHeight;
        var newWidth = 0;
        var newHeight = 0;
        delta = ( isNaN( delta )? 1 : delta + 1 );
        if ( msg.scrollHeight > msg.clientHeight ) {
                newHeight = msg.scrollHeight + delta;
        delta = msg.offsetWidth - msg.clientWidth;
        if ( msg.scrollWidth > msg.clientWidth ) {
                newWidth = msg.scrollWidth + delta;
        msg.style.overflow = "visible";
        if ( newWidth > 0 || newHeight > 0 ) {
                var ssxyzzy = document.getElementById( "ssxyzzy" );
                var cssAttribs = ['#' + msg.id + '{'];
                if ( newWidth > 0 ) cssAttribs.push( 'width:' + newWidth + 'px;' );
                if ( newHeight > 0 ) cssAttribs.push( ' height:' + newHeight + 'px;' );
                cssAttribs.push( '}' );
                try {
                        ssxyzzy.sheet.deleteRule( 0 );
                        ssxyzzy.sheet.insertRule( cssAttribs.join(""), 0 );
                } catch( e ){}
function imgsDone( msg )        // for Firefox, we need to scan for images that haven't set their width yet
        var imgList = msg.getElementsByTagName( "IMG" );
        var len = ((imgList == null)? 0 : imgList.length);
        for ( var i = 0; i < len; ++i ) {
                var theImg = imgList<i>;
                if ( ! theImg.complete && "undefined" != typeof theImg.naturalWidth && theImg.naturalWidth == 0 ) {
                        return false;
        return true;
var msg = document.getElementById( "message23631010564886435902706118501631720483800721033" );
if ( oBw.agt.match( /gecko/ ) == "gecko" ) { if ( msg && "undefined" != typeof msg ) { rmvScroll( msg ); }
} else { msg.style.visibility = "visible"; }
</script>
                                        <!-- END TOC -->
                                        <form name="showLetter2" method="post" action="/ym/ShowLetter?Idx=1&amp;Search=&amp;YY=52991&amp;y5beta=yes&amp;y5beta=yes&amp;order=down&amp;sort=date&amp;pos=0&amp;view=a&amp;head=b">
<input name=".crumb" value="GPcd9dY1IqW" type="hidden">                                                <input name="MsgId" value="2363_101056488_643590_2706_1185_0_16317_2048_3800721033" type="hidden">
<input name="box" value="Inbox" type="hidden">
<input name="MOV" value="" type="hidden">
<input name="NewFol" value="" type="hidden">
<input name="destBox" value="" type="hidden">
<input name="newfoldermessage" value="請輸入收件箱名稱。" type="hidden">
<input name="DEL" value="" type="hidden">
                                                <div id="contentbuttonbarbottom" class="contentbuttonbar">
<span class="first">
<button type="button" name="delete" id="deletebottom" value="Delete" onclick="Delete_Click(this);">刪除</button>
                                        <button type="button" value="Reply" id="replybottom" class="hasdefaultstate">回覆</button>
<button type="button" value="Forward" id="forwardbottom" class="hasdefaultstate">轉寄</button>
            <button type="button" value="濫發郵件" onclick="document.spamform.submit();">濫發郵件</button>
<button type="button" id="movebottom" name="move" class="menubutton" title="移送已選郵件">移至...</button>
</span>
</div>
        </form>
<div class="contentnav">
        <a href="http://hk.f366.mail.yahoo.com/ym/ShowLetter?box=Inbox&amp;MsgId=2363_101056488_643590_2706_1185_0_16317_2048_3800721033&ampREV=1&amp;inc=&amp;num=&amp;Idx=1&amp;Search=&amp;YY=52991&amp;y5beta=yes&amp;y5beta=yes&amp;order=down&amp;sort=date&amp;pos=0&amp;view=a&amp;head=b">上一頁</a>
        <a href="http://hk.f366.mail.yahoo.com/ym/ShowLetter?box=Inbox&amp;MsgId=2363_101056488_643590_2706_1185_0_16317_2048_3800721033&amp;NEXT=1&amp;inc=&amp;num=&amp;Idx=1&amp;Search=&amp;YY=52991&amp;y5beta=yes&amp;y5beta=yes&amp;order=down&amp;sort=date&amp;pos=0&amp;view=a&amp;head=b">下一頁</a>
        | <a href="http://hk.f366.mail.yahoo.com/ym/ShowFolder?box=Inbox&amp;YY=52991&amp;y5beta=yes&amp;y5beta=yes&amp;order=down&amp;sort=date&amp;pos=0&amp;view=a&amp;head=b" onmouseover="window.status='資料夾: 收件箱';return true" onmouseout="window.status=window.defaultStatus;return true">返回郵件</a>
                                                </span>
<span class="last">
                                                        </span></div>
 樓主| 發表於 16-5-2008 01:05:54 | 顯示全部樓層
 樓主| 發表於 16-5-2008 01:06:43 | 顯示全部樓層
 樓主| 發表於 17-5-2008 00:46:45 | 顯示全部樓層
 樓主| 發表於 18-5-2008 01:03:06 | 顯示全部樓層
 樓主| 發表於 18-5-2008 01:06:56 | 顯示全部樓層
<h2>緊急呼籲 全力參與 四川災民 賑災籌款</h2>
        <div id="postmessage_1042" class="t_msgfont"><font size="3"><font size="4"><font size="5"><font size="4"><font size="5"><strong><font color="Red">各位會員及同好:</font></strong></font><br>
  <br>本周初發生的四川 7.8 級大地震,至今已造成逾萬人死亡,數以萬計的受傷,災區滿目瘡痍,<span href="http://forum.vr2rc.org/tag.php?name=%A8a%A5%C1" onclick="tagshow(event)" class="t_tag">災民</span>亟待各界伸出援手!
身為中國人,同胞遇上急難,實應全力伸出援手。本“會”在此極力呼籲各會員及同好可慷慨解囊,響應<span href="http://forum.vr2rc.org/tag.php?name=%C4w%B4%DA" onclick="tagshow(event)" class="t_tag">籌款</span>募捐活動。<br>
  <br>救災工作刻不容緩,你的慷慨捐款及迅速支援有助紓解災情。如欲捐款,可循以下途徑:<br>
<br>1.        即場募捐:本“會”會所設有募捐箱,各會員�同好可即場募捐。<br>
<br>2.        劃線支票:支票抬頭請寫上「中華業餘無線電研究會有限公司」 或 “China Amateur Radio Study Club Ltd. ” <br><支票背面請註明「四川地震援助」>,<br>並於 5 月23 日前寄交本會;或劃線支票連同填妥的捐款回條一齊寄回(九龍佐敦上海街 61 至 67A 號嘉成大廈十樓)。<br>
<br>3.        直接存入南洋商業銀行戶口: 043-478-0-009720-2<br>
(請於 5 月 23 日前寄回存款收據正本並於背頁寫上姓名及聯絡電話,及注明「四川地震援助」,另請自行影印留底。)<br>
  <br>所謂「施比受更有福」,就讓我們萬眾同心,眾志成城,攜手戰勝這場歷史上罕見的天災!<br>
<br>如有查詢,請致電本會 梁小姐 2730 6776 (下午二時後)。<br>
</font></font></font></font><p align="right"><font size="3"><font size="4"><font size="5"><font size="4">中華業餘無線電研究會<br>
2008 年 5 月 15 日</font></font></font></font></p></div>
 樓主| 發表於 19-5-2008 17:36:50 | 顯示全部樓層
今天<font size="5"><span style="color: Red;">14:28</span></font>,大地靜默了。全國及世界多處為四川地震的死難者默哀三分鐘,並送上祝福。<br>國務院破天荒宣布,5月19日起一連3天全國哀悼,<font size="6"><span style="color: Red;">下半旗</span></font>誌哀、停止傳聖火等...1
GMT+8, 12-11-2026 14:50 , Processed in 0.134838 second(s), 26 queries , Gzip On.
