西貢 無線電獵狐 ( VR2 最大測向機群 )
 樓主| 發表於 23-6-2007 13:05:03 | 顯示全部樓層
西貢 無線電獵狐
<p class="MsoNormal"><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">The <a href="http://www.powersrvcs.org/w1gmf/foxhunt1.htm">South Shore Fox Hunters</a>
have had a lot of fun over the past 10 years chasing the elusive fox. They're
currently discussing a one-day hidden transmitter hunt, or "fox hunt"
involving members of the Whitman ARC, Massasoit ARA and the Taunton Area
Communications Group to "rekindle the flame" and introduce new hams
to the fascinating hobby of directional finding.<br>
According to Bruce Hayden, NI1X, "One member will be assigned to be the
fox and he or she will transmit on 146.565 MHz simplex for about 30 seconds
every five minutes between approximately 10:<st1:chmetcnv unitname="a" sourcevalue="0" hasspace="True" negative="False" numbertype="1" tcsc="0" w:st="on">00
a</st1:chmetcnv>.m. and noon on a Saturday morning. The Fox will be hiding in
a public place."<br>
The boundaries used in previous hunts were Route 44 on the south, Route 138 on
the West, Route 128 on the North and Route 3 on the East. Hayden says the group
would probably pick a smaller area "to save on gas."<br>
The fox hunters coordinate their activities on the <st1:City w:st="on"><st1:place w:st="on">Bridgewater</st1:place></st1:City> repeater on 147.180 MHz, PL 67.
Amateurs are invited to monitor from the home QTH or mobile and to check in at
10:<st1:chmetcnv unitname="a" sourcevalue="0" hasspace="True" negative="False" numbertype="1" tcsc="0" w:st="on">00 a</st1:chmetcnv>.m. at the start of the
hunt to report if you can hear the fox--or just as important--if you can not
hear the fox from your location. You never know when the fox will be hiding in
your back yard!<o:p></o:p></span></b></p>
 樓主| 發表於 23-6-2007 13:10:41 | 顯示全部樓層
西貢 無線電獵狐
<p class="MsoNormal" style="text-align: center;" align="center"><b><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">Rapid RDFing<br>
An Introductory Scouting Activity<o:p></o:p></span></b></p>
<p class="MsoNormal" style="text-align: center;" align="center"><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">By
Stan Pozerski KD1LE<o:p></o:p></span></b></p>
<div class="MsoNormal" style="text-align: center;" align="center"><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">
<hr align="center" color="#aca899" noshade="noshade" size="1" width="100%">
</span></b></div>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">I was recently asked to
participate in a Boy Scout Camporee and provide a demonstration program of some
aspect of Amateur Radio. There was to be a HF station and possibly some other
Amateur Radio activities available. Being an active Fox Hunter I thought I
could do radio direction finding independent of anything else so I threw my
gear in the car and headed off that Saturday morning not knowing what to
expect. The first thing I saw upon arriving at the site was the four vehicles
in the middle of the field stuck in the mud. So I parked on the road and walked
over to the HF station that was being set up. It was at the edge of a small
stand of trees about seventy-five feet across. This seemed a reasonable
arrangement so I decided to plant the fox on the opposite side of the stand in
the tall grass at the base of a few small trees. Returning to the HF station I
waited for the fox to transmit then set it to one-minute intervals for the
thirty second transmissions to keep things active. <o:p></o:p></span></b></p>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">I started to develop a
story line that would tie in to scouting to get the interest going. I pulled
out my fox hunting gear, hung the compass around my neck, map and HT in hand
(see above). It was a quick attraction. As the groups of scouts arrived I
handed one of the scouts the custom antenna with a FoxFinder (see QST April
2001) attached, and started the talk with how fox hunting was like Orienteering
having map and compass work with the added difficulty that you didn't know were
the end point was. Since the FoxFinder is an audio signal strength indicator it
was easy for the kids to swing the antenna and hear the signal change without a
lot of tutoring. With one or two sweeps of the antenna virtually all of them
could give a good direction. Quickly taking turns with the one-minute cycle we
projected virtual bearings into the trees. <br style="" clear="right">
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">After a couple of scouts
got bearings I moved them part way around the grove and gave a few more scouts
a chance with the antenna and FoxFinder. <o:p></o:p></span></b></p>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US"><br style="" clear="left">
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">After three or four
locations we estimated a spot where the bearings crossed and walked to the
location. Here I instructed the scouts in fox hunting etiquette. Among other
things this includes never revealing the location when you think you spot it
until every one gets a chance. Even though we were within ten feet at this
point no one found it accidentally. After another half dozen tries from within
ten feet the location of the fox was revealed. A couple of scouts were able to
correctly identify the disguised transmitter, which was remarkable as there was
other "junk" around and they had no idea at all what they might be
looking for. <o:p></o:p></span></b></p>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">I did this with ten groups
of four to eight scouts in about fifteen minute intervals without difficulty
and not losing any to other diversions. <o:p></o:p></span></b></p>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">The scouts caught on
quickly to the principle of directional antennas and audio signal strength
readings. <o:p></o:p></span></b></p>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">The signal strength
indication by tone variation was much easier than dealing with radio S meters
and attenuators. The near constant activity kept them from losing interest. <o:p></o:p></span></b></p>
<p class="MsoNormal" style=""><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US">If I were to do this
again, I would prepare some schematic maps of the area and have each scout plot
some of the bearings the group generated. This would combine some compass
skills with basic map skills. Each scout would take home his copy of the map as
a memento. And, of course, I would pre-print the blank maps with some Web
addresses to learn more about Amateur Radio. <o:p></o:p></span></b></p>
<p class="MsoNormal"><b style=""><span style="font-size: 16pt; font-family: Dotum;" lang="EN-US"><o:p>&nbsp;</o:p></span></b></p>
 樓主| 發表於 23-6-2007 22:31:20 | 顯示全部樓層
西貢 無線電獵狐
<p class="MsoNormal" style="text-align: center;" align="center"><span style="font-size: 16pt; font-family: SimHei;">無線電測向運動簡介</span><span style="font-size: 16pt; font-family: SimHei;"> </span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"><br>
</span><span style="font-size: 16pt; font-family: SimHei;">短距離無線電測向競賽規則</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style="text-align: center;" align="center"><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"><o:p>&nbsp;</o:p></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: SimHei;">一、 無線電測向技術的發展和應用
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> </span><span style="font-size: 16pt; font-family: SimHei;">在無線電通訊技術發展的早期,為了節省電臺的功率和確保通訊品質,人們曾對電磁波的定向發射和接收即定向天線進行了大量的研究。它為無線電測向奠定了基礎。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> 20</span><span style="font-size: 16pt; font-family: SimHei;">世紀初,無線電測向儀的使用,由於受體積和重量的限制,只能用於航海。<span lang="EN-US">40</span>年代,德國研製成功小型測向儀,裝在飛機上,利用倫敦廣播電臺的電磁波導 航,對倫敦進行了轟炸。 二次大戰末期,美國曾組織了一個大範圍的無線電測向網,監視德軍的潛艇,指引反潛飛機對其轟炸。反間諜鬥爭中,利用測向技術,可以破獲敵臺。在戰爭中,無
線電測向技術是一種重要的偵察手段,瞭解敵方指揮中心、部隊的配置和調動等。有的國家在軍隊中,專設有無線電測向隊。交戰雙方研製和改進測向設備,特別是 機載設備,有力的推動了無線電測向技術的發展。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> </span><span style="font-size: 16pt; font-family: SimHei;">無線電測向技術在和平建設時期,也廣泛的用於交通、天文、氣象、環保、救災中;航海規範及有關國際公約中規定,<span lang="EN-US">1600</span>總噸以上的海船,必須裝有測向儀, 用於海上救助。各擁有海岸線的國家要在沿海專設監測站,以便當接到緊急呼救信號後,測定遇難者的位置,派船和飛機救援。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> </span><span style="font-size: 16pt; font-family: SimHei;">近年來,比較先進的助航儀器,如羅蘭、奧米伽雷達大量使用,它們比測向儀操作簡便,定位精度高。但是一,由於無線電測向儀具有結構簡單、造價低、工作可靠、對電臺沒有特殊要求等優點,仍得到普遍的重視和應用。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> </span><span style="font-size: 16pt; font-family: SimHei;">無線電測向技術還可以用於檢查高壓配電系統中的瓷瓶漏電;用於監測陸上和海上動物的行蹤,以便對珍稀物種進行保護。如對國寶大熊貓、對鯨的監護等。隨著無
線電測向技術、知識的普及和無線電設備的小型化、微型化、我們不難想到,無線電測向技術一定會在更多、更廣泛的領域應用,為豐富人類生活、發展生產作出貢 獻。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: SimHei;">二、無線電測向運動現狀</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> </span><span style="font-size: 16pt; font-family: SimHei;">本世紀<span lang="EN-US">20</span>年代,美國的無線電愛好者,首先利用無線電波來尋找發迅台。接著,<span lang="EN-US">40</span>年代、挪威、丹麥、英國等陸續開展了遊戲性無線電測向儀活動。隨之波及歐洲,並增加了一些競賽內容。使用頻段也有所增加。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> 1956</span><span style="font-size: 16pt; font-family: SimHei;">年,國際業餘無線電聯盟(<span lang="EN-US">LARU</span>)第一區,批准了南斯拉夫關於制定國際比賽規則的建議,並委託瑞典負責起草工作,於<span lang="EN-US">1960</span>年由國際業餘無線電 聯盟一區執委會討論通過。解決了由於各國測向活動使用頻段不同、活動方式不同,不便於相互交往等問題,推動了測向運動的發展。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> 1960</span><span style="font-size: 16pt; font-family: SimHei;">年,在賴比錫舉行了首次歐洲國際無線電測向競賽。<span lang="EN-US">1961</span>年<span lang="EN-US">8</span>月,在瑞典首都斯德哥爾摩舉行了第一屆歐洲無線電測向錦標賽,直到<span lang="EN-US">1997</span>年,歐洲共舉行了<span lang="EN-US">8</span>次錦標賽。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> 1977</span><span style="font-size: 16pt; font-family: SimHei;">年,在南斯拉夫科普裏舉行的國際業餘無線電聯盟第一區無線電測向工作會議上,決定將歐洲錦標賽擴大為世界錦標賽。<span lang="EN-US">1979</span>年通過了新的競賽規則。 <span lang="EN-US">1980</span>年<span lang="EN-US">9</span>月第一屆世界無線電測向錦標賽在波蘭格旦斯克舉行,有聯邦德國、瑞典等<span lang="EN-US">11</span>國參加。<span lang="EN-US">1984</span>年<span lang="EN-US">9</span>月,在挪威奧斯陸舉行了第二屆世界無線電測向 錦標賽,有保、中、朝、德蘇等<span lang="EN-US">12</span>國參賽。蘇聯奪得大部分金牌,中國隊嶄露頭角,獲三枚銀牌。在此之前,<span lang="EN-US">1983</span>年<span lang="EN-US">7</span>月,中國對首次出征, 在南斯拉夫第<span lang="EN-US">27</span>屆國際無線電測向錦標賽中,奪得<span lang="EN-US">4</span>個第一。之後,世界錦標賽每兩年舉行一次、到<span lang="EN-US">1992</span>年為止共舉行的六屆世界錦標表賽中,中國對在第四
屆、第五界都獲得了很好的成績,第四屆是五金、一銀、一銅;第五屆是一金、一銀 ,一銅,吉林姑娘韓春榮兩次榮獲冠軍稱號。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: SimHei;">三、 中國起步在頤和園</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> </span><span style="font-size: 16pt; font-family: SimHei;">在無線電測向方面,我國起步略晚於歐洲,但在亞洲是先行。<span lang="EN-US">1960</span>年我國派觀察員去歐洲觀摩了國際無線電測向競賽之後,中國人民無線電俱樂部(國家体委航
空無線電模型運動管理中心的前身)開始籌建測向隊。<span lang="EN-US">1961</span>年<span lang="EN-US">5</span>月,解放軍、河北、無線電俱樂部隊等共<span lang="EN-US">30</span>餘名男、女隊員,在頤和園進行了首次比賽。此 後,組織幾支小分隊輾轉全國示範、培訓。自此,中國的無線電測向運動事業開始起步。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> 1962</span><span style="font-size: 16pt; font-family: SimHei;">年,在北京香山舉行了第一屆全國無線電測向錦標賽,無線電測向運動面向全國展開,逐步普及。<span lang="EN-US">1964</span>年的全國比賽,參賽隊多達<span lang="EN-US">24</span>個。文化革命開始後,無線電測向活動全面停滯。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 16pt; font-family: 新細明體;" lang="EN-US">&nbsp;&nbsp;&nbsp;</span><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"> 1979</span><span style="font-size: 16pt; font-family: SimHei;">年 ,河南率先恢復了無線電測向活動,各省事相繼開展。<span lang="EN-US">1980</span>年國家体委正式列項。<span lang="EN-US">1984</span>年在吉林省吉林市舉行了首次全國青少年競賽。後來,由國家体委、
國家教委、中國科協、共青團中央、全國婦聯五家聯合主辦的每年一次的全國青少年賽一直堅持至今。為在青少年中,特別是中、小學生中普及測向活動創造了良好 的條件。</span><span style="font-size: 16pt; font-family: SimHei;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal"><span style="font-size: 16pt; font-family: SimHei;" lang="EN-US"><o:p>&nbsp;</o:p></span></p>
 樓主| 發表於 23-6-2007 22:34:00 | 顯示全部樓層
體育性、科技性、趣味性是無線電測向的突出特點
<p class="MsoNormal" style=""><span style="font-size: 14pt; font-family: NSimSun;">什麼是無線電測向運動?</span><span style="font-size: 14pt; font-family: NSimSun;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 14pt; font-family: NSimSun;">無線電測向運動是競技體育項目之一,也是業餘無線電活動的主要內容。它類似于從所周知的捉迷藏遊戲,但它是尋找能
發射無線電波的小型信號源(即發射機),是無線電捉迷藏,是現代無線電通訊技術與傳統捉迷藏遊戲的結合。大致過程是:在曠野、山丘的叢林或近郊、公園等優 美的自然環境中,事先隱藏好數部信號源,定時發出規定的電報信號。參加者手持無線電測向機,測出隱蔽電臺的所在方向,採用徒步方式,奔跑一定距離,迅速、
準確地逐個尋找出這些信號源。以在規定時間內,找滿指定台數、實用時間少者為優勝。通常,我們把事先巧妙隱藏起來的信號源比喻成狡猾的狐狸,故此項運動又 稱無線電<span lang="EN-US">"</span>獵狐<span lang="EN-US">"</span>或抓<span lang="EN-US">"</span>狐狸<span lang="EN-US">"</span>。</span></p><p class="MsoNormal" style=""><br><span style="font-size: 14pt; font-family: NSimSun;"></span><span style="font-size: 14pt; font-family: NSimSun;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><font size="6"><span style="font-size: 14pt; font-family: NSimSun;">體育性、科技性、趣味性是無線電測向的突出特點</span></font></p><p class="MsoNormal" style=""><br><font size="6"><span style="font-size: 14pt; font-family: NSimSun;"></span></font><span style="font-size: 14pt; font-family: NSimSun;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-size: 14pt; font-family: NSimSun;">參加該項活動,除要進行身體訓練外,還需要學習無線電方面的知識,要掌握測向機或其他電子製作技能,這無
疑將豐富和延伸其課堂知識,使課堂學習更輕鬆。而且在當今電子技術無孔不入的時代,會因為有了這一技之長而終生常駐益。由於無線電測向既不是純科技性的室 內製作,又不是固定場地上的單一奔跑,而是充分體現了理論與實踐、動手與動腦、室內與戶外、體能與智力的結合。是在大自然的懷抱中,有機地將科技、健身、
休閒、娛樂融為一體。對於開闊視野、增長知識、增強體魄、磨練意志,進行國防教育,培養獨立思考和分析判斷的能力,促進青少年德、智、體、美、勞全面發 展,豐富學校第二課堂內容及從應試教育向素質教育轉化均十分有益,同時也符合中央關於<span lang="EN-US">"</span>在青少年中普及科技和實施《全民健身計畫綱要》的精神,故備受學校 和有關主管部門的重視,有不少地區制定了對取得一定成績的運動員,在升學考試中給予加分錄取的政策,就充分說明這一點。同時也深得家長支持和青少年的喜
愛。目前南京等地已將此項活動推向社會,引進家庭,他們利用雙休日,回歸大自然,開展社會和家庭<span lang="EN-US">"</span>無線電獵狐遊戲<span lang="EN-US">"</span>,豐富了渡假內容,增添了家庭情趣。 </span><span style="font-size: 14pt; font-family: NSimSun;" lang="EN-US"><br>
</span><span style="font-size: 14pt; font-family: 新細明體;" lang="EN-US"> </span><span style="font-size: 14pt; font-family: NSimSun;" lang="EN-US"> <o:p></o:p></span></p>
<p class="MsoNormal"><span style="font-size: 14pt; font-family: NSimSun;" lang="EN-US"><o:p> </o:p></span></p>
 樓主| 發表於 24-6-2007 01:02:53 | 顯示全部樓層
西貢 無線電獵狐
 樓主| 發表於 24-6-2007 07:35:09 | 顯示全部樓層
西貢 無線電獵狐
 樓主| 發表於 24-6-2007 07:35:55 | 顯示全部樓層
西貢 無線電獵狐
 樓主| 發表於 24-6-2007 07:36:32 | 顯示全部樓層
西貢 無線電獵狐
GMT+8, 12-11-2026 12:30 , Processed in 0.270386 second(s), 26 queries , Gzip On.
