2007黃岩島BS7H遠征活動圓滿結束
 樓主| 發表於 21-4-2007 09:53:07 | 顯示全部樓層
黃岩島遠征
 樓主| 發表於 24-4-2007 09:54:26 | 顯示全部樓層
黃岩島遠征
<span style="font-size: 16pt; font-family: 新細明體;">黃岩島遠征記<span lang="EN-US"><br>
<br>
<br>
</span>作者<span lang="EN-US">: </span>陳方<span lang="EN-US"> / BA4RC<br>
&nbsp; &nbsp; <st1:chsdate year="1997" month="4" day="30" islunardate="False" isrocdate="False" w:st="on">1<font size="6">997<span lang="EN-US"><span lang="EN-US">年4</span></span><span lang="EN-US"><span lang="EN-US">月30</span></span><span lang="EN-US"><span lang="EN-US">日</span></span></font></st1:chsdate><span lang="EN-US"><font size="6">晨</font>,由中國無線電運動協會組織的業餘無線電探險隊,經過30</span></span>多小時的航行,踏上了祖國南海最東端的島嶼<span lang="EN-US">--</span>黃岩島,一股世界性的<span lang="EN-US">"</span>中 國黃岩島熱<span lang="EN-US">"</span>由此進入高潮。黃岩島歷來為我國領土。它位於東經<span lang="EN-US">117</span>度<span lang="EN-US">47</span>分,北緯<span lang="EN-US">15</span>度<span lang="EN-US">07</span>分,距離廣州<span lang="EN-US">500</span>多海裏<span lang="EN-US">(1</span>海裏約等於<st1:chmetcnv unitname="公里" sourcevalue="1.8" hasspace="False" negative="False" numbertype="1" tcsc="0" w:st="on"><span lang="EN-US">1.8</span>公里</st1:chmetcnv><span lang="EN-US">)</span>,距離 菲律賓蘇比克港不足<span lang="EN-US">100</span>海裏。這是一個由珊瑚礁構成的幾乎成等邊三角形的<span lang="EN-US">"</span>環礁<span lang="EN-US">"</span>,環外是<span lang="EN-US">1,<st1:chmetcnv unitname="千米" sourcevalue="2" hasspace="False" negative="False" numbertype="1" tcsc="0" w:st="on">2<span lang="EN-US"><span lang="EN-US">千米</span></span></st1:chmetcnv><span lang="EN-US">的深海,環內平均水深不足<st1:chmetcnv unitname="米" sourcevalue="10" hasspace="False" negative="False" numbertype="1" tcsc="0" w:st="on">10<span lang="EN-US"><span lang="EN-US">米</span></span></st1:chmetcnv><span lang="EN-US">,形態各異的珊瑚和</span></span></span>
色彩斑瀾的小魚在環內棲息繁衍,星星點點露出海面的礁石如珍珠般撒落在約<span lang="EN-US">30</span>多公里長的環線上。黃岩島的地理位置,對於我國神聖領土的完整性,對於開發南
海的經濟,其重要性不言而喻。<span lang="EN-US"> <br>
&nbsp; &nbsp; </span>這是經國家體委和外交部批准,中國無線電運動協會組織的第<span lang="EN-US">3</span>次登黃岩島活動。與前<span lang="EN-US">2</span>次不同的是,這次是由<font size="6">我國自己的船隻,從我國本土廣州出發</font>,並由來自全 國各地的愛好者參加。</span>
 樓主| 發表於 27-4-2007 06:51:52 | 顯示全部樓層
黃岩島遠征
<p class="MsoNormal" style=""><b><span style="font-family: 新細明體;" lang="EN-US">BS7H - </span></b><b><span style="font-family: 新細明體;">聯絡指南</span></b><span style="font-family: 新細明體;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<div class="MsoNormal" style="text-align: center;" align="center"><span style="font-family: 新細明體;" lang="EN-US">
<hr align="center" color="#d1d1e1" noshade="noshade" size="1" width="100%">
</span></div>
<p class="MsoNormal" style=""><b><span style="font-family: 新細明體;">摘自<st1:chsdate year="2007" month="3" day="30" islunardate="False" isrocdate="False" w:st="on"><span lang="EN-US">2007</span>年<span lang="EN-US">3</span>月<span lang="EN-US">30</span>日</st1:chsdate>『江蘇<span lang="EN-US">HAM</span>』小報</span></b><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><span style="font-family: 新細明體;">本次<span lang="EN-US">BS7H</span>操作將在<st1:chmetcnv unitname="米" sourcevalue="160" hasspace="False" negative="False" numbertype="1" tcsc="0" w:st="on"><b><span lang="EN-US">160</span>米</b></st1:chmetcnv><b>到<st1:chmetcnv unitname="米" sourcevalue="10" hasspace="False" negative="False" numbertype="1" tcsc="0" w:st="on"><span lang="EN-US">10</span>米</st1:chmetcnv>所有業餘波段上,用<span lang="EN-US">SSB</span>、<span lang="EN-US">CW</span>和<span lang="EN-US">RTTY</span></b>等多種方式工作。為了確認自己是否聯絡成功,可以登錄<b><span style="color: red;" lang="EN-US"><a href="http://www.bs7h.com/" target="_blank">http://www.bs7h.com</a></span></b>網站,從線上聯絡日誌<span lang="EN-US">online logs</span>中查詢記錄。如有差錯,抓緊時間再<span lang="EN-US">QSO.</span>由於是典型的<span lang="EN-US">“</span>稀有台<span lang="EN-US">”</span>,屆時必然會呼叫聲連成一片。</span><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><span style="font-family: 新細明體;">為提高效率,<span lang="EN-US">BS7H</span>的操作員必然會採用<b>異頻工作方式</b>,在比呼叫高<span lang="EN-US"> 5 kHz</span>左右的一段頻率範圍內<span lang="EN-US">“</span>遊動<span lang="EN-US">”</span>收聽。我們要想聯絡<span lang="EN-US">BS7H</span>,應該先聽一下其呼叫內容,</span><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><span style="font-family: 新細明體;">一是注意是否有<span lang="EN-US">"<b>UP5</b>"</span>之類的內容,二是有沒有在<span lang="EN-US">“</span><b>分區呼叫</b><span lang="EN-US">”</span>,要求按呼號分區數或按地區回答。還要注意聽其他台在什麼頻率範圍內呼叫,然後再發射。</span><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><b><span style="font-family: 新細明體;">千萬不要貿然在<span lang="EN-US">BS7H</span>的呼叫頻率上直接發射,干擾別人的收聽和聯絡</span></b><span style="font-family: 新細明體;">。當然遠征隊中的中國<span lang="EN-US">HAM</span>也一定會找機會專門呼叫<span lang="EN-US">"Bravo"</span>,以滿足國內<span lang="EN-US">HAM</span>的需求。</span><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><span style="font-family: 新細明體;">成功的<span lang="EN-US">DX</span>遠征,包含了全體遠征隊員執著的艱苦努力,包含組織者的嘔心瀝血,包含著眾多朋友和有關單位的支持幫助,更離不開千萬愛好者的關心和回應。朋友們,行動起來,做好準備,抓住這珍貴的一瞬間,讓與<span lang="EN-US">BS7H</span>的<span lang="EN-US">QSO</span>成為你業餘無線電生涯中閃亮的一頁。</span><span style="font-family: 新細明體;" lang="EN-US"><o:p></o:p></span></p>
<p class="MsoNormal"><span style="" lang="EN-US"><o:p>&nbsp;</o:p></span></p>
 樓主| 發表於 27-4-2007 07:12:41 | 顯示全部樓層
黃岩島遠征
 樓主| 發表於 27-4-2007 07:16:35 | 顯示全部樓層
JSDXC成為BS7H 2007獨家國內贊助組織
<p class="MsoNormal" style=""><b><span style="font-family: 新細明體;" lang="EN-US">JSDXC</span></b><b><span style="font-family: 新細明體;">成為<span lang="EN-US">BS7H 2007</span>獨家國內贊助組織</span></b><span style="font-family: 新細明體;"> <span lang="EN-US"><o:p></o:p></span></span></p>
<p class="MsoNormal" style=""><span style="font-family: 新細明體;" lang="EN-US"><o:p>&nbsp;</o:p></span></p>
<p class="MsoNormal" style=""><span style="font-family: 新細明體;" lang="EN-US">2007 </span><span style="font-family: 新細明體;">年<span lang="EN-US">3</span>月,經多方工作,江蘇遠征俱樂部(<span lang="EN-US">JSDXC</span>)向<span lang="EN-US">BS7H 2007</span>提供<span lang="EN-US">USD 1000</span>的現金贊助,成員<span lang="EN-US">BA4TB</span>個人也進行了另外的贊助。<span lang="EN-US">BS7H</span>是全體<span lang="EN-US">JSDXC</span>成員的夢想之地。歷史上,來自<span lang="EN-US">JSDXC</span>的成員參加了每一次的 <span lang="EN-US">BS7H</span>操作。本次活動將有<span lang="EN-US">3</span>名來自<span lang="EN-US">JSDXC</span>的隊員參與實地操作。俱樂部衷心祝願<span lang="EN-US">BS7H 2007</span>的所有隊員一路平安,活動取得圓滿成功。</span><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><span style="font-family: 新細明體;">詳情見:<span lang="EN-US"><a href="http://www.scarboroughreef.com/srclub.html" target="_blank">http://www.scarboroughreef.com/srclub.html</a><br>
<br>
</span>關於<span lang="EN-US">JSDXC<br>
</span>江蘇遠征俱樂部,成立於<span lang="EN-US">1998</span>年,英文名稱為<span lang="EN-US">Jiangsu
DX Club</span>,簡稱<span lang="EN-US">JSDXC</span>。本俱樂部系致力於遠距離業餘無線電通信活動(<span lang="EN-US">DX</span>)的團隊,由業餘無線電愛好者組成,在江蘇省無線電運動協會的指導下,面向全球愛好者,自我管理並獨立開展活動。</span><span style="font-family: 新細明體;" lang="EN-US"><br>
</span><span style="font-family: 新細明體;">俱樂部設立的目的是吸收合法、優秀、積極且熱心的業餘無線電愛好者,並依靠會員組織各種業餘無線電通信活動,從而提高自身會員的能力和水準,增進相互瞭解和友誼,創造良好的競賽成績,促進遠距離業餘無線電通信活動的普及開展和提高。</span><span style="font-family: 新細明體;" lang="EN-US"><br>
<br>
</span><span style="font-family: 新細明體;" lang="EN-US">GO GO</span><span style="font-family: 新細明體;">!<span lang="EN-US">BS7H </span>!<span lang="EN-US"><br>
GO GO</span>!<span lang="EN-US">JSDXC!<br>
<br>
<br>
</span>江蘇遠征俱樂部<span lang="EN-US"><br>
2007</span>年<span lang="EN-US">4</span>月<span lang="EN-US"><br>
<a href="http://www.jsdxc.net/" target="_blank">http://www.jsdxc.net</a><o:p></o:p></span></span></p>
<p class="MsoNormal"><span lang="EN-US"><o:p>&nbsp;</o:p></span></p>
 樓主| 發表於 30-4-2007 14:48:57 | 顯示全部樓層
黃岩島遠征
 樓主| 發表於 2-5-2007 12:55:40 | 顯示全部樓層
黃岩島遠征
 樓主| 發表於 5-5-2007 20:53:34 | 顯示全部樓層
黃岩島遠征
 樓主| 發表於 13-5-2007 00:05:07 | 顯示全部樓層
10年後又再Q得 BS7H
10年後又再Q得 BS7H
 樓主| 發表於 13-5-2007 00:06:35 | 顯示全部樓層
10年後又再Q得 BS7H
GMT+8, 12-11-2026 14:04 , Processed in 0.134221 second(s), 26 queries , Gzip On.
