流行 手機7R 車機706-857 台機FT2000 V/U/50/HF
 樓主| 發表於 23-11-2006 10:29:14 | 顯示全部樓層
IC-706MKIIG 與 IC-706MKII 的主要差異
VHF 加大為 50 W, 增加了UFH 20W, 內部增加一個濾波器插槽, IC-706MKIIG 以全新內涵現身
IC-706MKIIG 的詳細規格表
IC-706MKIIG 與 IC-706MKII 的主要差異:
增加了UFH 20W Power
VHF 加大為 50 W
包含了 DSP
加掛 Tone Squelch (加裝 UT-86 )
自動化中繼設定
按鍵背光照明
相同的體積, 擁有更多的功能:
附加的次旋鍵, 操作 RIT 及 第二有效工作頻率更有效率
2 米波有 50 watts
獨立的波段選擇鍵
新特徵:
Crossband split
Band stacking register memorizes preamp/attenuator settings and tuner on/off condition as well as fewquency and mode
"S" menu has 3 band quick access
更好的音質
大尺寸喇叭
高品質的傳送音質
高效力散熱風扇
上一款 IC-706MkII 詳細資料
3 Step Selectable Passband Width
The IC-706MkII has improved passband width selection. A maximum of 2 optional crystal filter units can be installed, providing a total of 3 passband widths selectable in SSB, CW, or RTTY mode.
Tone Squelch Function is Available
The IC-706MkII has an optional tone squelch unit, UT-86, for FM mode operation: useful during 144 MHz band and 6 meter band operation. In addition, a programmable CTCSS subaudible tone and a 1750 Hz tone encoder are standard.
Simplified Operation
An individual band change key and a SUB DIAL simplify operation. The individual band change keys provide quick and easy QSY, while the SUB DIAL facilitates mobile operation and memory operation. Each band stores pre-amplifier/attenuator and tuner ON/OFF settings. In addition RIT variable range adjustment is more convenient because the SUB DIAL is used for RIT control.
Superior Audio Characteristics
The SSB filter is a newly designed FL-272 (2.4 kHz/-6dB, 4.8 kHz/-60db). A large 66 mm (d) speaker provides plenty of audio. Together they help the IC-706MkII provide superior receive and transmit audio characteristics.
Thermally Controlled Cooling Fan
The internal cooling fan is thermally controlled to reduce cooling fan noise during receiving.
Compact and Feather Light
The IC-706MkII is incredibly small with dimensions of 167(w) x 58(h) x 200(d) mm (6-9/16 x 2-9/32 x 7-7/8 inches). A mobile sized transceiver packed with base station features. Excellent performance allows this transceiver to be used as your main rig for the HF and VHF bands. Of course many will be tempted to use the IC-706 MkII for mobile operation and on DX'peditions. Whatever your choice you can't go wrong.
Detachable Front Panel
The IC-706MkII sports a detachable front panel. Both the main unit and detachable front panel have microphone connectors providing numerous mounting options in both a vehicle or a shack.
IF Shift Interference Rejection System
IF shift is effective to reduce adjacent frequency interference in SSB, and enables comfortable operation even under crowded band conditions, such as during contests. The IF shift setting condition is graphically indicated on the LCD.
Functions for CW Operations
--Electronic keyer with a variable weight control function.
--CW reverse function to reduce adjacent interference.
--CW pitch can be adjusted in the range of 300-900 Hz.
--CW narrow mode (optional CW narrow filter is required).
--Full break-in (QSK) is available.
Spectrum Scope Function
Sweeps ?4 steps from, the displayed frequency and plots received signal strength on the function display. This function is useful not only for seeking vacant channels during VHF/FM operation, but also for checking HF band conditions.
Narrow-FM Capability
Narrow-FM mode is becoming increasingly popular. Narrow-FM capability is available not only in the 10 M band, but also the 2 M band, allowing you to take maximum advantage of this operating style. Deviation is ?.5 kHz for transmit and ? kHz for receive.
102 Memory Channels with Alphanumeric Names
The IC-706MkII has up to 102 memory channels. 99 channels are split memories that can memorize both transmit and receive frequencies individually. 2 channels are for programmed scan edges, and 1 channel is for call memory on the 144 MHz band. In addition, up to 9-character alphanumeric names can be programmed into each memory channel. This provides a convenient memory management system.
Dot-Matrix Display
The IC-706MkII's large LCD has a dot-matrix readout under the frequency display. By using the menu-function switch you can clearly read multi-function key descriptions on the LCD. Moreover, the graphical menu function indicates transmit frequency during split frequency operation, IF shift setting, spectrum scope indication, memory channel name indication, etc.
Voice Synthesizer
The optional voice synthesizer unit, UT-102, provides a unique speech function. A clear, electronically generated voice announces not only operating frequency and modes, but also the current S-meter level.
Optional Antenna Tuner
An optional, fully automatic antenna tuner, the AT-180, is available and covers the 3.5 MHz to 50 MHz bands. Style and size are matching with the IC-706MkII.
MORE OUTSTANDING FEATURES
--WFM mode for listening to FM broadcasting, etc.
--Digital S-meter with peak-hold function
--Variable SSB carrier-point
--Auto tuning step selection
--Speech compressor
--Built-in pre-amplifier
--RIT, VOX and noise blanker are standard
--Built-in CI-V serial communications port
More specifications and options for the new IC-706MkII
*This device has not been approved by the FCC. This device may not be offered for sale or lease, or be sold or leased until the approval of the FCC has been obtained.
 樓主| 發表於 27-11-2006 07:09:32 | 顯示全部樓層
v8
 樓主| 發表於 27-11-2006 15:47:27 | 顯示全部樓層
817
 樓主| 發表於 29-11-2006 00:46:47 | 顯示全部樓層
706
 樓主| 發表於 29-11-2006 00:49:13 | 顯示全部樓層
706
 樓主| 發表於 29-11-2006 00:50:22 | 顯示全部樓層
706
 樓主| 發表於 5-12-2006 01:13:39 | 顯示全部樓層
ft2000
 樓主| 發表於 5-12-2006 11:05:22 | 顯示全部樓層
FT2000
 樓主| 發表於 5-12-2006 11:10:44 | 顯示全部樓層
FT 857
 樓主| 發表於 8-12-2006 01:44:14 | 顯示全部樓層
IC-2720H
V/V,U/U同時接收能力
IC-2720H 是獨特的雙波段車載電臺。除VHF/UHF全雙工操作以外還提供VHF/VHF、UHF/UHF同時接收能力。簡單的按鍵操作即可改變發射波段。
每波段獨立控制
ICOM對稱設計的寬大液晶顯示器,同時操作兩個波段非常簡單,即使在側面也可方便地閱讀分別顯示的兩個波段的設定。IC-2720分別為左右兩側的各波段提供分離的調諧、音量、靜噪旋鈕和功能鍵。通過分離的左右兩個波段的音頻插孔,可以單獨收聽各波段的通訊。
動態存儲掃描(DMS)
ICOM獨有的動態存儲掃描系統提供給您靈活的掃描方式,可以定制10個存儲庫的212個頻道。
寬波接收
IC-2720H優秀的寬波接收,覆蓋118-550MHz和810-999MHz,您可以聽到幾乎所有通訊。
HM-133,遙控麥克風
ICOM獨有的"熱鍵"(F1/F2)功能可以記憶最常用的發射機設定。
CTCSS和DTCS
除音頻掃描功能以外,IC-2720H還包含104×2個DTCS和50個CTCSS音頻編碼。不要因為沒有選擇音頻編碼而遺漏通信。"尋呼提示音"功能在收到呼叫時給提供給您即能聽到又可看見的指示。
緊湊小巧的控制頭
具備3.5米線長電纜的控制頭安裝簡單。當主機安裝在遠處或特殊位置時,仍然可以靈活方便的操控收發信機。另外,在控制頭和主機上均設置有麥克風介面。
其他特性
•10dB RF衰減器•可選擇靜噪抑制•9600bps資料傳輸終端(迷你6針介面)•選配件MB-85可將控制器裝於主機上•12個DTMF記憶頻道(24位元)•輔助波段自動靜音功能•MOS-FET功率放大
技 術 指 標
一般指標
頻率範圍
發射144-148,430-440MHz
接收 :左 118-550 右 118-174,375-550,810-999.990
模式 :FM、AM
頻道數 :212(2個呼叫頻道,10個掃描邊緣)
天線阻抗 :50Ω(SO-239)
電源 :13.8V DC ±15%
溫度範圍 :-10℃ ∼ +60℃
頻偏 :±10ppm
頻率步進 :5,10,12.5,15,20,25,30,50kHz
電流(13.8V) :待機 1.2A
        最大音量 1.8A
        發射(VHF)12A、(UHF)11A
尺寸 :控制面板 140x50 x 27mm
    主機 140x50 x 187mm
重量 :控制面板 150g
    主機 1.4kg
發射指標
輸出功率 :VHF 50W、20W、5W
      UHF 35W、20W、5W
最大頻偏 :±5.0kHz
雜波發射 :小於-60dB
麥克風阻抗 :600Ω(標準6針介面)
接收指標
接收系統 :雙路轉換外差式
中頻 :1中頻38.85/46.05MHz
    2中頻450/455kHz
靈敏度 :小於0.18μV
靜噪靈敏度 :小於0.13μV
選自性 :大於12kHz/-6dB
     小於30kHz/-60dB
雜波遮罩 :大於60dB
音頻輸出功率 :大於2.4W/10%失真/ 8Ω負載
外接揚聲器 :2芯3.5mm(直徑)/ 8Ω負載
GMT+8, 12-11-2026 13:40 , Processed in 0.143431 second(s), 26 queries , Gzip On.
