CQ游~803紀念電台ARES
 樓主| 發表於 11-8-2019 20:34:03 | 顯示全部樓層
 樓主| 發表於 13-8-2019 00:42:58 | 顯示全部樓層
 樓主| 發表於 13-8-2019 00:49:39 | 顯示全部樓層
 樓主| 發表於 13-8-2019 08:46:12 | 顯示全部樓層
 樓主| 發表於 14-8-2019 00:10:12 | 顯示全部樓層
 樓主| 發表於 14-8-2019 02:24:44 | 顯示全部樓層
 樓主| 發表於 14-8-2019 10:59:42 | 顯示全部樓層
 樓主| 發表於 15-8-2019 00:44:06 | 顯示全部樓層
NOAA圖片格式
The Automatic Picture Transmission (APT) system is an analog image transmission system developed for use on weather satellites. It was introduced in the 1960s and over four decades has provided image data to relatively low-cost user stations at locations in most countries of the world. A user station anywhere in the world can receive local data at least twice a day from each satellite as it passes nearly overhead.
Transmission
                        The APT transmission format
Structure
The broadcast transmission is composed of two image channels, telemetry information, and synchronization data, with the image channels typically referred to as Video A and Video B. All this data is transmitted as a horizontal scan line. A complete line is 2080 pixels long, with each image using 909 pixels and the remainder going to the telemetry and synchronization. Lines are transmitted at 2 per second, which equates to a 4160 words per second, or 4160 baud.
 樓主| 發表於 15-8-2019 00:48:18 | 顯示全部樓層
Images
On NOAA POES system satellites, the two images are 4 km / pixel smoothed 8-bit images derived from two channels of the advanced very-high-resolution radiometer (AVHRR) sensor. The images are corrected for nearly constant geometric resolution prior to being broadcast; as such, the images are free of distortion caused by the curvature of the Earth.
Of the two images, one is typically long-wave infrared (10.8 micrometers) with the second switching between near-visible (0.86 micrometers) and mid-wave infrared (3.75 micrometers) depending on whether the ground is illuminated by sunlight. However, NOAA can configure the satellite to transmit any two of the AVHRR's image channels.
 樓主| 發表於 15-8-2019 00:57:11 | 顯示全部樓層
GMT+8, 12-11-2026 15:44 , Processed in 0.195366 second(s), 26 queries , Gzip On.
