查看: 7747|回覆: 12
CQ旅行-石硤尾山-5兆NVIS
發表於 29-4-2019 10:13:01 | 顯示全部樓層 |閲讀模式
CQ旅行-石硤尾山-5兆NVIS
 樓主| 發表於 29-4-2019 10:17:53 | 顯示全部樓層
 樓主| 發表於 29-4-2019 20:22:27 | 顯示全部樓層
 樓主| 發表於 30-4-2019 08:08:32 | 顯示全部樓層
 樓主| 發表於 30-4-2019 08:20:23 | 顯示全部樓層
建基於對頻譜特性的需求,業界代表不斷的努力,
世界無線電大會終於通過把 5MHz (5351.5~5366.5KHz),
於IARU R3(國際電訊聯盟第3區)開放為業餘無線電頻段。
 樓主| 發表於 1-5-2019 01:21:56 | 顯示全部樓層
 樓主| 發表於 1-5-2019 19:02:53 | 顯示全部樓層
 樓主| 發表於 2-5-2019 09:28:41 | 顯示全部樓層
發表於 3-5-2019 21:05:27 | 顯示全部樓層
5月4日(星期六) 1400 - 2100衛星通過時程預測
 樓主| 發表於 3-5-2019 22:22:54 | 顯示全部樓層
AO-85 carries a U/V FM repeater operating at up to 800mw. Uplink was planned for 435.180, but initial reports indicate it may be closer to 435.172 due to unforeseen temperature differences. Repeater access requires the satellite to receive a 67.0 Hz PL tone for two seconds. If the satellite does not receive a signal carrying a 67.0 Hz PL tone, the repeater will turn off after one minute. When the repeater is not activated by a signal carrying the PL tone, a voice beacon is transmitted every two minutes.
Downlink is 145.980 and includes Data Under Voice (DUV) FSK telemetry simultaneous with repeater operation. A high speed data downlink at 9600 bps is available for experiment and high resolution data. In addition to the amateur operations, there are a number of scientific experiments on board the spacecraft.
GMT+8, 12-11-2026 13:37 , Processed in 0.241864 second(s), 28 queries , Gzip On.
