CQ旅行 12月29日
 樓主| 發表於 23-12-2018 22:06:04 | 顯示全部樓層
 樓主| 發表於 24-12-2018 19:59:22 | 顯示全部樓層
 樓主| 發表於 26-12-2018 00:23:31 | 顯示全部樓層
11
 樓主| 發表於 26-12-2018 19:20:54 | 顯示全部樓層
 樓主| 發表於 27-12-2018 18:15:50 | 顯示全部樓層
發表於 28-12-2018 09:31:03 | 顯示全部樓層
衛星時程    2018-12-29
發表於 28-12-2018 09:50:45 | 顯示全部樓層
FO-29 (JAS-2)
FO-29 carries a 100KHz wide SSB/CW linear transponder that operates in mode V/U. It additionally carries a 1k2/9k6 digital BBS that is no longer operational and a Digitalker beacon that transmits a digital voice on FM.  FO-29 includes an attitude control system that consists consists of a sun-sensor, geomagnetism sensor, magnetorquer and data processor. It also features an advanced solar cell experiment consisting of gallium-arsenide solar cells 2cm x 2cm and 2cm x 1cm cells.
Mode V/U (J) Linear Transponder (Inverting):
Uplink: 145.9000 – 146.0000 MHz SSB/CW
Downlink 435.8000 – 435.9000 MHz SSB/CW
Mode U Beacon:
Downlink 435.7950 MHz CW
Mode U Digitalker (Rarely Used):
Downlink 435.9100 MHz FM
SO-50 satellite
SO-50 carries several experiments, including a mode J FM amateur repeater experiment operating on 145.850 MHz uplink and 436.795 MHz downlink. The repeater is available to amateurs worldwide as power permits, using a 67.0 Hertz PL tone on the uplink, for on-demand activation. SO-50 also has a 10 minute timer that must be armed before use. Transmit a 2 second carrier with a PL tone of 74.4 to arm the timer.
The repeater consists of a miniature VHF receiver with sensitivity of -124dBm, having an IF bandwidth of 15 KHz. The receive antenna is a 1/4 wave vertical mounted in the top corner of the spacecraft. The receive audio is filtered and conditioned then gated in the control electronics prior to feeding it to the 250mW UHF transmitter. The downlink antenna is a 1/4 wave mounted in the bottom corner of the spacecraft and canted at 45 degrees inward.
Information from : www.amsat.org
 樓主| 發表於 28-12-2018 18:38:42 | 顯示全部樓層
 樓主| 發表於 30-12-2018 01:44:57 | 顯示全部樓層
 樓主| 發表於 2-1-2019 13:06:51 | 顯示全部樓層
GMT+8, 12-11-2026 20:54 , Processed in 0.183010 second(s), 26 queries , Gzip On.
