CQ旅行-獅子山新測試-3月24日
 樓主| 發表於 20-4-2018 19:31:36 | 顯示全部樓層
 樓主| 發表於 20-4-2018 19:37:29 | 顯示全部樓層
 樓主| 發表於 20-4-2018 19:41:42 | 顯示全部樓層
 樓主| 發表於 21-4-2018 00:57:41 | 顯示全部樓層
 樓主| 發表於 21-4-2018 22:52:38 | 顯示全部樓層
 樓主| 發表於 21-4-2018 22:57:33 | 顯示全部樓層
 樓主| 發表於 21-4-2018 23:00:52 | 顯示全部樓層
 樓主| 發表於 21-4-2018 23:07:41 | 顯示全部樓層
 樓主| 發表於 22-4-2018 21:15:47 | 顯示全部樓層
AO-85 (Fox-1A)
AO-85 (formerly Fox-1A) is the first of AMSAT’s Fox-1 series of 1U cubesats. Launched as part of ELaNa XII on the October 8th, 2015 NROL 55 Atlas 5 launch from Vandenburg, California, AO-85 is in a roughly 65 degree inclination, 518x810km orbit with apogee over the northern hemisphere.
AO-85 carries a U/V FM repeater operating at up to 800mw. Uplink was planned for 435.180, but initial reports indicate it may be closer to 435.172 due to unforeseen temperature differences. Repeater access requires the satellite to receive a 67.0 Hz PL tone for two seconds. If the satellite does not receive a signal carrying a 67.0 Hz PL tone, the repeater will turn off after one minute. When the repeater is not activated by a signal carrying the PL tone, a voice beacon is transmitted every two minutes. Downlink is 145.980 and includes Data Under Voice (DUV) FSK telemetry simultaneous with repeater operation. A high speed data downlink at 9600 bps is available for experiment and high resolution data.
 樓主| 發表於 22-4-2018 21:22:39 | 顯示全部樓層
重點是:
上行FM發射435。180兆
亞音67Hz
下行FM接收145。980兆
GMT+8, 12-11-2026 16:43 , Processed in 0.133864 second(s), 26 queries , Gzip On.
