CQ旅行 惠陽最高峰 白雲嶂10月28日
 樓主| 發表於 5-10-2017 22:51:11 | 顯示全部樓層
 樓主| 發表於 6-10-2017 20:49:13 | 顯示全部樓層
 樓主| 發表於 7-10-2017 23:36:14 | 顯示全部樓層
 樓主| 發表於 8-10-2017 21:36:54 | 顯示全部樓層
 樓主| 發表於 9-10-2017 23:58:09 | 顯示全部樓層
 樓主| 發表於 11-10-2017 01:45:23 | 顯示全部樓層
發表於 11-10-2017 13:40:14 | 顯示全部樓層
_
 樓主| 發表於 11-10-2017 23:59:41 | 顯示全部樓層
 樓主| 發表於 12-10-2017 20:38:22 來自手機 | 顯示全部樓層
AO-85 carries a U/V FM repeater operating at up to 800mw. Uplink was planned for 435.180, but initial reports indicate it may be closer to 435.172 due to unforeseen temperature differences. Repeater access requires the satellite to receive a 67.0 Hz PL tone for two seconds. If the satellite does not receive a signal carrying a 67.0 Hz PL tone, the repeater will turn off after one minute. When the repeater is not activated by a signal carrying the PL tone, a voice beacon is transmitted every two minutes. Downlink is 145.980 and includes Data Under Voice (DUV) FSK telemetry simultaneous with repeater operation. A high speed data downlink at 9600 bps is available for experiment and high resolution data. In addition to the amateur operations, there are a number of scientific experiments on board the spacecraft. Vanderbilt University is providing a Low Energy Proton radiation experiment, and Penn State University V Erie a gyroscope experiment.
FoxTelem is a multi-platform telemetry program for these formats. You can download it from:
http://amsat.us/FoxTelem/windows
http://amsat.us/FoxTelem/mac
http://amsat.us/FoxTelem/linux
The telemetry leaderboard can be found here: http://www.amsat.org/wordpress/tlm/
Join AMSATSupport the Fox Project
Support ARISS
AMSAT-NA Facebook Group
Jerry Buxton
9 hours ago
NASA TV coverage of the JPSS-1 launch carrying the ELaNa XIV mission and RadFxSat/Fox-1B.
nasa.gov
The Joint Polar Satellite System-1 (JPSS-1), the first in a new series of four highly advanced NOAA polar-orbiting satellites, which will help increase weather forecast accuracy from three to seven days out, is scheduled to launch on Friday, Nov. 10, from Vandenberg Air Force Base, California.
View on FacebookP[url=]Share[/url]
Selwyn Cathcart
9 hours ago
Hello All,
Hope someone in our community can assist me?
I am seeking a download location for a WIN 10 version of the satellite tracking programme called SimpleSat by Tom Doyle.
There is another satellite tracking application also written by Tome Doyle called SimpleSat Look Down, however I am not too sure if there is a version of this application able to run on a Win 10 platform?
Any help is very welcome.
Regards from down under.
Selwyn ZL2BJO V M0IHF
Michael Johnson
13 hours ago
Michael Johnson shared a link to the group: AMSAT North America.
mwrf.com
Growing use of satellites for communications, navigation, weather, and other functions is boosting the demand for active and passive components.
Radio Amateur Satellite Corporation
AMSAT-NA
10605 Concord St, #304
Kensington, MD 20895-2526 USA
Toll-Free: +1 (888) 322-6728
Phone: +1 (301) 822-4376
Fax: +1 (301) 822-4371
info@amsat.org
ⒸCopyright 2017. All Rights Reserved.
amsat.org | login
[url=https://www.amsat.org/two-way-satellites/ao-85-fox-1a/#][/url]
 樓主| 發表於 13-10-2017 20:49:36 | 顯示全部樓層
Uplink (MHz): 435.172
Downlink (MHz): 145.980
Beacon (MHz): 145.980
Mode: FM CTCSS 67.0Hz/200bps DUV/9k6 FSK
Call sign:
Status: Active
GMT+8, 12-11-2026 16:13 , Processed in 0.142960 second(s), 26 queries , Gzip On.
