CQ 旅行 屏山文物徑+達德公所 9月24日
 樓主| 發表於 20-9-2017 19:20:44 | 顯示全部樓層
 樓主| 發表於 21-9-2017 20:01:43 | 顯示全部樓層
發表於 21-9-2017 23:45:50 | 顯示全部樓層
_
 樓主| 發表於 22-9-2017 19:07:21 | 顯示全部樓層
 樓主| 發表於 23-9-2017 18:33:16 | 顯示全部樓層
fo29
Mode V/U (J) Linear Transponder (Inverting):
Uplink: 145.9000 – 146.0000 MHz SSB/CW
Downlink 435.8000 – 435.9000 MHz SSB/CW
Mode U Beacon:
Downlink 435.7950 MHz CW
 樓主| 發表於 23-9-2017 20:01:51 | 顯示全部樓層
NOAA 18, known before launch as NOAA-N, is a weather forecasting satellite run by NOAA. NOAA-N (18) was launched into a sun-synchronous orbit at an altitude of 854 km above the Earth, with an orbital period of 102 minutes. It hosts the AMSU-A, MHS, AVHRR, Space Environment Monitor SEM/2 instrument and High Resolution Infrared Radiation Sounder (HIRS) instruments, as well as the SBUV/2 ozone-monitoring instrument. NOAA 18 is the first NOAA POES satellite to use MHS in place of AMSU-B. APT transmission frequency is 137.9125 MHz (NOAA-18 changed frequencies with NOAA-19 on June 23, 2009).
 樓主| 發表於 23-9-2017 23:36:18 | 顯示全部樓層
GMT+8, 12-11-2026 15:32 , Processed in 0.228526 second(s), 26 queries , Gzip On.
