樓主: VR2VBU
新一轮 ISS SSTV 活动即将到来
發表於 11-4-2018 13:55:37 | 顯示全部樓層
The transmissions which were coordinated with the ARISS scheduling team, will be made on 145.800 MHz FM using the PD-120 SSTV mode.
Note the ISS transmissions use the 5 kHz deviation FM standard rather than the narrow 2.5 kHz used in Europe. If your transceiver has selectable FM filters try using the wider filter. Handheld transceivers generally have a single wide filter fitted as standard and you should get good results outdoors using just a 1/4 wave whip antenna.
The ISS Fan Club site will show you when the space station is in range
發表於 12-4-2018 00:16:05 | 顯示全部樓層
發表於 12-4-2018 00:38:29 | 顯示全部樓層
發表於 12-4-2018 00:43:35 | 顯示全部樓層
發表於 12-4-2018 22:39:12 | 顯示全部樓層
發表於 13-4-2018 20:52:22 | 顯示全部樓層
發表於 14-4-2018 14:58:20 | 顯示全部樓層
ISS  SSTV, 2018 Apr 14, UTC 03:50
發表於 14-4-2018 21:46:58 | 顯示全部樓層
發表於 15-4-2018 21:21:52 | 顯示全部樓層
ISS  SSTV, 2018 Apr 14, UTC 10:26
發表於 7-6-2018 15:53:55 | 顯示全部樓層
Tuesday, May 29, 2018
Inter-MAI SSTV for short periods on June 6-7
Here are the targeted times for Inter-MAI SSTV operations (subject to change): June 6, 12:30-14:30 UTC and June 7, 11:50-15:25 UTC. Check your orbits to see if ISS will be in range of your location in those time blocks.
**UPDATE 5/30**
Looks like another activity has shifted the SSTV end time to allow another pass on June 6. End time now 16:30 UTC.
GMT+8, 12-11-2026 20:48 , Processed in 0.234259 second(s), 26 queries , Gzip On.
