樓主: VR2VBU
新一轮 ISS SSTV 活动即将到来
發表於 25-7-2017 01:04:16 | 顯示全部樓層
發表於 25-7-2017 13:32:57 | 顯示全部樓層
ISS SSTV on 2017-07-21, 21:56 (UTC)
發表於 25-7-2017 13:48:06 | 顯示全部樓層
發表於 25-7-2017 13:51:00 | 顯示全部樓層
Our SSTV image is posted in the ARISS SSTV archive.
發表於 26-7-2017 21:38:09 | 顯示全部樓層
發表於 8-8-2017 14:04:00 | 顯示全部樓層
ISS SSTV on 2017-07-24, 12:41 (UTC)
發表於 16-8-2017 13:40:34 | 顯示全部樓層
Our SSTV image are posted in the ARISS SSTV archive.
發表於 3-12-2017 07:32:38 | 顯示全部樓層
MAI-75 in December 2017
發表於 9-12-2017 10:19:38 | 顯示全部樓層
2017 Dec 08
發表於 11-4-2018 13:53:27 | 顯示全部樓層
[size=1em]AMSAT-UK
Russian ISS SSTV Event to Celebrate Cosmonautics Day[size=0.875em] m5aka
[size=0.875em]2 days ago
[size=0.875em]ISS SSTV image received by Mike Rupprecht DK3WN April 12, 2016 at 1556 UT
ARISS Russia is planning a special Slow Scan Television (SSTV) event April 11-14 from the International Space Station in celebration of Cosmonautics Day.
The transmissions are to begin on April 11 at 11:30 UT and run through April 14 ending at 18:20 UT.
Supporting this event is a computer on the ISS Russian Segment, which stores images that are then transmitted to Earth using amateur radio, specifically the onboard Kenwood TM-D710E transceiver.
Transmitted images will be from the Interkosmos project period of the Soviet space program https://en.wikipedia.org/wiki/Interkosmos
The transmissions which were coordinated with the ARISS scheduling team, will be made on 145.800 MHz FM using the PD-120 SSTV mode.
Note the ISS transmissions use the 5 kHz deviation FM standard rather than the narrow 2.5 kHz used in Europe. If your transceiver has selectable FM filters try using the wider filter. Handheld transceivers generally have a single wide filter fitted as standard and you should get good results outdoors using just a 1/4 wave whip antenna.
The ISS Fan Club site will show you when the space station is in range http://www.issfanclub.com/
ISS SSTV information and links at https://amsat-uk.org/beginners/iss-sstv/
Post your images on the ARISS-SSTV gallery at http://www.spaceflightsoftware.com/ARISS_SSTV/
Listen to the ISS when it is over Russia with the R4UAB WebSDR http://websdr.r4uab.ru/
Listen to the ISS when in range of London with the SUWS WebSDR http://farnham-sdr.com/
Please note that the event is dependent on other activities, schedules and crew responsibilities on the ISS and subject to change at any time. You can check for updates regarding planned operation at:
ISS Ham https://twitter.com/RF2Space
ARISS Status https://twitter.com/ARISS_status
ARISS SSTV Blog https://ariss-sstv.blogspot.com/
AMSAT Bulletin Board http://www.amsat.org/mailman/listinfo/amsat-bb
If you receive a full or partial picture from the Space Station your Local Newspaper may like to know http://www.southgatearc.org/news/2016/july/now-is-a-great-time-to-get-ham-radio-publicity.htm
The RSGB produce a handy Media Guide and Template press release for anyone to download and adapt, see http://rsgb.org/main/clubs/media-guide-for-affiliated-societies/
An example of the publicity you can get for the hobby by telling your Local Newspaper
https://amsat-uk.org/2015/04/15/iss-sstv-in-the-press/
[size=0.875em]Categories: Daily Updates
[size=0.875em]Tags: Amateur Radio, Ham Radio, ISS, SSTV
AMSAT-UK[size=0.8em]Back to top
GMT+8, 12-11-2026 19:47 , Processed in 0.138389 second(s), 26 queries , Gzip On.
