CQ 旅行 4月27日 香港極西雞翼角
 樓主| 發表於 21-4-2014 18:17:14 | 顯示全部樓層
 樓主| 發表於 21-4-2014 23:13:00 | 顯示全部樓層
11
 樓主| 發表於 22-4-2014 18:36:59 | 顯示全部樓層
 樓主| 發表於 23-4-2014 23:40:32 | 顯示全部樓層
發表於 24-4-2014 14:34:47 | 顯示全部樓層
Satellites :
 樓主| 發表於 24-4-2014 18:11:19 | 顯示全部樓層
 樓主| 發表於 24-4-2014 18:13:04 | 顯示全部樓層
 樓主| 發表於 25-4-2014 23:56:37 | 顯示全部樓層
 樓主| 發表於 26-4-2014 01:15:53 | 顯示全部樓層
NOAA-15 (designated NOAA-K before launch) is one of the NASA-provided TIROS series of weather forecasting satellite run by NOAA. It was launched on 13 May 1998, and is currently operational, in a sun-synchronous orbit, 807 km above the Earth, orbiting every 101 minutes. It hosts the AMSU-A and AMSU-B instruments, the AVHRR and High Resolution Infrared Radiation Sounder (HIRS/3) instruments, as well as a Space Environment Monitor (SEM/2).[6]
APT transmission frequency is 137.62 MHz. Due to problems with the S-band transmitter high-gain antennas, NOAA-15 has been configured for High Resolution Picture Transmission using the S-Band Transmitter #2 (1702.5 MHz) omnidirectional antenna.[7]
 樓主| 發表於 26-4-2014 18:48:31 | 顯示全部樓層
GMT+8, 14-11-2026 10:40 , Processed in 0.231104 second(s), 26 queries , Gzip On.
