查看: 5611|回覆: 1
出讓 IC-208H
發表於 26-12-2012 00:38:16 | 顯示全部樓層 |閲讀模式
Brand: ICOM
Model: IC-208H
Frequency (MHz): 144 / 430
O/P Power (Watt): 55/50
Type: VHF/UHF Amateur
High Power Dual Bander with Wideband Receiver
Powerful 55W/50W output power
Individual MOS-FET power amplifier modules supply the power for Icom's most powerful dual band mobile with 55W/50W (VHF/UHF). Stable power for long distance communications plus reduced power settings (15/5W) for local communications.
Wideband receiver
See why Icom has a world renowned reputation for superb wideband receivers with the IC-208H. The IC-208H wideband receiver covers 118-173, 230-549 and 810-999MHz* as standard. Listen to your Amateur VHF/UHF bands, as well as aviation, marine, weather and other utility communications in a compact mobile package. Extends your mobile radio enjoyment!
* Excluding Cellular range.
Detachable front panel
Limited installation space is no problem with the IC-208H. The separation cable, OPC-600/R, is supplied with the radio allowing the compact remote control head* to be installed almost anywhere.
* 111 (W) × 40(H) × 26.3 (D) mm; 43/8 × 19/16 × 11/32 in.
500 alphanumeric memory channels
With this much memory, you can fill your IC-208H with your favorite frequencies and operation settings such as output power, tone, and more! Then name each memory channel with up to 6 characters for quick channel identification.
Improved Dynamic Memory Scan (DMS) system
The improved DMS system allows you to scan all the selected banks you want to scan by simply adding/deleting bank links with Icom's exclusive Bank Link system. Yet another convenient feature to make the IC-208H a more practical radio.
 樓主| 發表於 26-12-2012 00:40:53 | 顯示全部樓層
IC-208H 九成新
沒有盒, 沒有說明書 (可自行在 網上下載說明書 )
購買價約 $2800, 現出讓價 $2000
Amateur_IC-208H Brochure.pdf
4.49 MB, 下載次數: 774
GMT+8, 12-11-2026 11:06 , Processed in 0.174932 second(s), 28 queries , Gzip On.
