最新 衛星 ARIS-Sat-1 VR2首試
 火 [複製鏈接]
發表於 14-8-2011 01:14:05 | 顯示全部樓層
Reply by ARIS Sat-1 Team
發表於 14-8-2011 09:44:22 | 顯示全部樓層
ARIS Sat-1 SSTV Image is posted by AMSAT
The image posted by AMSAT was captured on 2011 Aug 12 at 20:06 (UTC 12:06), QTH: VR2RC
The ARIS Sat-1 call sign RS01S is shown on the upper left-hand corner.
Rig: FT-857, Antenna: DIY 3-element YaGi
The image can be found at www.amsat.org as follows:
http://www.amsat.org/amsat/ariss/SSTV/uploads/3767.jpg
 樓主| 發表於 15-8-2011 09:09:13 | 顯示全部樓層
8月15日 過境情況理想
 樓主| 發表於 15-8-2011 22:38:40 | 顯示全部樓層
發表於 16-8-2011 00:10:09 | 顯示全部樓層
下鏈得 ARIS-SAT-1   電子語音 的ID-(RS01S) 和15種 各國 問候語之第二種
0 2011-AUG-12 問侯-02.mp3 (575.61 KB, 下載次數: 543)
發表於 16-8-2011 13:33:02 | 顯示全部樓層
VR2UIO 發表於 16-8-2011 00:10
ARISSat-1 Battery is Failing Faster Than Expected
The ARISSat-1 battery performed as expected during the first week of operation. Lower voltages during eclipse began to show up in the telemetry on 10 Aug 2011. The voltages during eclipse have continued to decline causing the satellite to reset and go into Emergency power mode on 12 Aug.
After reset the satellite MET (Mission Elapsed Timer) goes to 000, waits during the 15 minute TX delay, the power management software checks the current voltage and power values and determines what power mode to operate the satellite. The power mode is re-determined at fixed intervals, especially during illuminated periods to provide the most transmitted signals while protecting the battery.
High power mode provides continuous transmission when sunlight is charging the battery. If the satellite has entered low power mode it will transmit for 40 seconds and remain idle for 2 minutes when in eclipse, or when the battery voltage is low.
Additional information and explanation about the operation of the ARISSat-1/RadioSkaf-V power system can be found on the arissat1.org web site under the FAQ section.
The ARISSat-1 team is closely monitoring the situation and is pleased with how well the power management software is controlling the battery usage to prolong the lifetime of the battery and the satellite as much as possible.
 樓主| 發表於 17-8-2011 13:02:55 | 顯示全部樓層
ARISSat-1 Telemetry - Mobile Version
This telemetry was received on Wed, 17 Aug 2011 04:46:53 UTC
3692
00d:01h:01m:32s
Mode: HIGH PWR
Status
RF         ACTIVE
IHU         ACTIVE
SDX         ACTIVE
5 volt         ACTIVE
8 volt         ACTIVE
Battery
Batt Voltage        36.024 V
Batt Current        -0.012 A
2.5V Ref         05.054 V
Net Amp Hours        421944629119.757 A
Battery is        Discharging
Power Consumption
Camera        0.082 A         5945425
Experiment         0.200 A         48186248
RF        0.469 A         63936551
IHU        0.072 A         15022142
SDX        0.243 A         42382657
5 volt         0.572 A         76292772
Temperatures
IHU         48 ° C
PSU         50 ° C
RF         51 ° C
Top Camera         62 ° C
Bottom Camera        33 ° C
Control Panel        54 ° C
Experiment         52 ° C
ARISSatTLM website by
Douglas Quagliana, KA2UPW/5.
Gilbert Mackall, N3RZN
Version 0.05
 樓主| 發表於 18-8-2011 01:51:32 | 顯示全部樓層
ARISSat-1/KEDR at +10 Days: ON-ORBIT and OPERATIONAL
Hundreds of reception reports have been received since ARISSat-1/KEDR was deployed from the ISS. Full operational capability of the satellite has been confirmed in the 10 days since the start of the mission on August 3.
The satellite's power system monitors the battery voltage and switches between High power mode (continuous transmission) when sunlight is charging the battery and Low power mode (40 seconds transmit/2 minutes idle) when in eclipse. Telemetry data shows that the ARISSat-1 Battery voltage is decreasing each eclipse period. It therefore is taking longer for the battery to charge up to 32.5V to allow the switch from Low Power to High Power when the satellite enters an illumination period.
Kenneth Ransom, N5VHO has plotted the battery min/max for the last 8 days. The data shows that the battery voltage is decreasing at a faster rate than expected. Kenneth's graph can be found on the arissat1.org site under FAQ: http://tinyurl.com/3e5c2y8 (arissat1.org)
The effect of this is that ARISSat-1/KEDR remains in Low power mode for a period of time after exiting eclipse. The team recommend that users take advantage of the High Power mode as much as possible over the next few days.
435 MHz - 145 MHz Linear Transponder - OPERATIONAL
The linear transponder operates in Mode U/V (70 cm Up, 2m Down). It is an 16 KHz wide inverting passband. The convention is to TX LSB on the 435 MHz uplink and RX USB on the 145 MHz downlink. Several amateur radio operators have been reporting successful contacts via the linear transponder.
After the initial success with the linear transponder reported by KO4MA, K8YSE, KD8CAO, and JN1GKZ last week news of addition contacts have been received from amateur radio operators worldwide:
    * Henk, PA3GUO uplinked an SSTV signal to the linear transponder and received the picture on the downlink. He posted a copy of the reccecived image at: http://www.pa3guo.com/pa3guo_arissat1_sstv_9aug2011_0258utc.jpg His station configuration was:
          o Uplink HW: TS2000X, 435MHz, 5W RF power + 12 elements beam
          o Downlink HW: FunCubeDongle (SDR) + SP-2000 preamp + 2x6 elements beam
          o Downlink SW: MMSSTV + DK3WN Satcontrol (doppler/freq control) + HDSDR
    * Andre, ZS2BK reported a successful two-way CW contact with Pierre, ZS6A on August 5.
    * Alex, VK5ALX reported a contact with Geoff, VK2ZAZ on August 6.
    * Bruce, VE9QRP was able to access the linear transponder with 40 watts into a Lindenblad on TX and another omni on receive. Bruce commented, "It's an amazing thrill to work our AMSAT SDX for the first time, and my sense is that any VO-52 class station should be able to hear its downlink."
    * Luciano, PY5LF had a contact with Roland, PY4ZBZ and recorded it:
      http://www.youtube.com/watch?v=oJ2Gujm2vtc
145.950 MHz FM Downlink - OPERATIONAL
145.919 MHz CW Beacons - OPERATIONAL
The CW transmissions include the satellite callsign ID RS01S, select telemetry, and callsigns of people actively involved with the ARISS program.
145.920 MHz SSB BPSK-1000 Telemetry - OPERATIONAL
AMSAT needs your telemetry from ARISSat-1/KEDR. Since there are no "Whole Orbit Data" storage mechanisms onboard ARISSat-1/KEDR, your submissions are the only way for AMSAT to collect the spacecraft telemetry and KURSK experiment results.
    * Recorded file ARISSat-1/KEDR and Kursk telemetry CSV files (in the ARISSatTLM folder) can be sent as an e-mail attachment to: telemetry@arissattlm.org
    * If you are running ARISSatTLM and receiving the signal "live" from ARISSat-1/KEDR, please enable the telemetry forwarding option.
    * The latest telemetry can be seen LIVE on your computer or cell phone at:
      http://www.arissattlm.org/mobile
Peter Miller, W1AMJ, the Hartford Hobby Radio writer published a story about the deployment of ARISSat-1 in the Hartford Examiner newspaper and at: http://tinyurl.com/4yo3l2m (Examiner.com)
NASA Education Office is getting the word out on ARISSat-1 in their article, "Hammin' It Up":
http://www.nasa.gov/audience/foreducators/hammin-it-up_prt.htm
[ANS thanks the ARISSat-1/KEDR Team for the above information]
Send For Your ARISSat-1/KEDR Certificates
When you receive the downlink signal from ARISSat-1/KEDR you are invited to send your report to the following e-mail boxes. You will receive a PDF certificate by e-mail.
Students and school groups are especially welcome! We look forward to your report!
Your report must contain the following information:
    * The signal you received:
          o the secret word*
          o an SSTV image, or
          o telemetry data
    * Your name or group name
    * The date/time of reception
    * Your e-mail address of where to send your certificate. You will receive a PDF certificate via email.
Here are the e-mail boxes to send your reports:
    * Secret word* contest to: secretword@arissat1.org
    * SSTV image to: sstvreport@arissat1.org
    * Telemetry data to: tlmreport@arissat1.org (either digital or voice report of the data you received)
    * Received BPSK telemetry and .CSV files should continue to be sent to:
* Those who do hear the secret word or call sign please do not put it out to the world. That would ruin the contest for those still waiting for their station to be in range.
You can find the details of the ARISSat-1/KEDR radio frequencies, links to telemetry decoding software and mission details on-line at:
    * http://www.amsat.org
    * http://arissat1.org
ARISSat-1/KEDR can be accessed on these frequencies:
    * 145.950 MHz FM Downlink
    * 435 MHz - 145 MHz Linear Transponder
    * 145.919 MHz CW Beacon
    * 145.920 MHz SSB BPSK-1000 Telemetry
TRACK STATUS on OSCAR STATUS PAGE
David Carr, KD5QGR has added ARISSat-1/KEDR to the list of satellites at the popular "Live OSCAR Satellite Status Page" at: http://oscar.dcarr.org/ You are invited to submit your reports on this page.
Reminder: The DARA Matching Gift Challenge Runs Until September 1
Donate to AMSAT and DARA will contribute matching funds. The Dayton Amateur Radio Association (DARA) fund raising challenge for AMSAT continues until September 1, 2011. DARA will match $1.00 for every $3.00 donated up to $5,000.00.
AMSAT kicked off the fundraising campaign at the Hamvention, where donations began count for the challenge. Please consider making a donation to AMSAT and have your effort multiplied. We appreciate DARA's support for AMSAT!
Your donation will support our "Getting AMSAT Back Into Space" campaign by providing needed funds for AMSAT Project Fox Cubesat which will provide a 2M to 70cm FM transponder matching the performance of AO-51.
    * On-line at the AMSAT Store: http://www.amsat-na.com/store/donation.php
    * You may click on the donation widget on our http://www.amsat.org web page.
    * You may call Martha at the AMSAT Office:
      From the US call toll free at: (888) 322-6728
      From all other locations call: (301) 589-6062
      and you can send a fax to: (301) 608-3410
    * You can send donations by postal mail to:
      AMSAT-NA
      850 Sligo Ave #600
      Silver Spring, MD, 20910
發表於 18-8-2011 21:50:48 | 顯示全部樓層
本帖最後由 VR2VBU 於 19-8-2011 09:32 編輯
VR2GY 發表於 18-8-2011 01:51
http://www.youtube.com/watch?v=w9iKIRsTEFw
Hundreds of reception reports have been rece ...
12 August 2011 ARIS-Sat-1 signal by VR2GY, VR2VBU, VR2UIO, VR2UGP
衛星 ARIS-Sat-1 VR2首試
發表於 19-8-2011 18:39:23 | 顯示全部樓層
本帖最後由 VR2VBU 於 19-8-2011 18:42 編輯
VR2VBU 發表於 18-8-2011 21:50
衛星 ARIS-Sat-1 VR2首試
VR2VBU 在 九龍東, 配合 VR2GY, VR2UGP, VR2UIO 測試
GMT+8, 12-11-2026 15:17 , Processed in 0.219490 second(s), 26 queries , Gzip On.
