查看: 27063|回覆: 48
來自太空的..測試++SSTV
發表於 21-12-2014 23:53:10 | 顯示全部樓層 |閲讀模式
來自太空的SSTV
 樓主| 發表於 21-12-2014 23:54:18 | 顯示全部樓層
來自太空的SSTV
 樓主| 發表於 22-12-2014 18:49:33 | 顯示全部樓層
Dec 18 SSTV from ISS active
Starting to see reports of activity from ISS on Dec 18 around 14:00 UTC. This image from PY2IV was captured during a pass over Brazil.
Additionally, below is another image from F5ASD in France. Notice the series numbers in the upper right corner of the images. Each image is a celebration of the 80th anniversary of Gagarin's birth. Wonder if anyone will get all 12?
 樓主| 發表於 23-12-2014 00:41:28 | 顯示全部樓層
Get Ready for SSTVfrom the ISS in Mid December
Russian SSTV transmissionsare planned from the International Space Station on December 18 and 20. Thetransmit frequency will be 145.800 MHz with a 3 minute off time betweentransmissions.
The expected mode is PD180producing a high quality image with a frame scan of 187 seconds. A total of 12different photos will be sent throughout an operation period.
Image transmissions for Dec.18 should begin around 14:20 UTC and on Dec. 20, look for signals to startaround 12:40 UTC. For both days, operation is expected to terminate around21:30 UTC.
 樓主| 發表於 23-12-2014 00:52:41 | 顯示全部樓層
Thank you Li Lee    CHAN Ken ( VR2GY VR2UIO VR2UGP VR2WOS )  for submitting this image for consideration.
The volunteer review team has been notified of your submission.
Please be patient while one of the volunteers evaluates your image. Please do not submit duplicate copies of the same image!  Thank you.
You may apply for a QSL or SWL card through one of the ARISS QSL bureaus listed in theARRL ARISS FAQ.
Return to the main page
 樓主| 發表於 23-12-2014 12:44:32 | 顯示全部樓層
 樓主| 發表於 23-12-2014 18:33:53 | 顯示全部樓層
 樓主| 發表於 24-12-2014 18:29:04 | 顯示全部樓層
發表於 26-12-2014 13:53:48 | 顯示全部樓層
__
發表於 26-12-2014 21:44:17 | 顯示全部樓層
__
本討論區基於 Discuz! X5.0|版權所有 © 2005-2026 VR2GY.com,保留一切權利
在本版發帖返回頂部
